Motor 1,4 TDCi od PSA
Goto page 1, 2, 3, 4, 5, 6  Next
Black storm
PostPosted: Tue Feb 20, 2007 8:29 pm    Post subject: Motor 1,4 TDCi od PSA Reply with quote
Zaujimali by ma technicke parametre motora 1,4 TDCi od Peugeotu /Fusion vyrobeny v 2004/, ake ma vstrekovace, cerpadlo, trysky atd.
Vie to niekto ?
Ford Fusion 1,4 TDCi 12/2004,
PostPosted: Wed Feb 21, 2007 8:19 am    Post subject: Reply with quote
no, vela som o tom nenasiel. V nejakom ceskom casaku bolo ze pouziva siemens piezoelektricke vstrekovace ktore su vraj najspolahlivejsie. Vi je to pravda netusim.
Viac info o motore som nasiel len na
http://en.wikipedia.org/wiki/Ford_DLD_engine
DLD-414
The Duratorq DLD-414 (or DV4) is a 1.4 L (1398 cc/85 in³) straight-4 turbo-Diesel. Output is 50 kW (67 hp) at 4500 rpm and 160 N·m (117 ft·lbf) at 2000 rpm.
The DV4 is available in two versions:
One, an 8-valve design, uses a Borg-Warner KP35 turbocharger but no intercooler. This is the same turbocharger as the Renault K9K Diesel. It is EURO3 compliant, but will receive a Diesel particulate filter from 2006 to make it EURO4 compliant. It also uses Delphi Automotive's DCR1400 common-rail injection system.
A second version uses a DOHC 16-valve design, with an intercooled variable geometry turbine. This derivation will no longer be built from 2006, as it will not be able to comply with the EURO4 regulations.
Applications:
8-value non-intercooled, 55 PS (54 hp/40 kW) and 96 ft·lbf (130 N·m)
2005-present Citroën C1/Peugeot 107/Toyota Aygo 1.4 HDi
8-valve non-intercooled, 68 PS (67 hp/50 kW) and 111 ft·lbf (150 N·m)
2003–present Citroën C2 1.4 HDi
8-valve non-intercooled, 68 PS (67 hp/50 kW) and 118 ft·lbf (160 N·m)
2002–present Citroën C3 1.4 HDi
2002–present Ford Fiesta 1.4 TDCi
2002–present Ford Fusion (European) 1.4 TDCi
2002–present Peugeot 206 1.4 HDi
2005–present Peugeot 1007 1.4 HDi
16-valve intercooled, 90 PS (89 hp/66 kW) and 147 ft·lbf (200 N·m)
2001–2005 Citroën C3 1.4 HDi 16V
2002–2005 Suzuki Liana 1.4 DDiS
Model Output Notes
DV4 TD 70 PS (69 hp/51 kW) turbo-Diesel
DV4 TED4 92 PS (90 hp/67 kW) turbo-Diesel 16-valve
ak mate ktosi cosi viac, pastnite
PostPosted: Wed Feb 21, 2007 8:25 am    Post subject: Reply with quote
nasiel som tdci club :) celkom zaujimave informacie o zabehu a podobne
http://communityhosting.net/tdiclub/index.php/Break-In_Guide
PostPosted: Thu Feb 22, 2007 8:17 pm    Post subject: Reply with quote
Tu som hodil nejake udaje o 1,4 TDCI....je to v ZIP formate...staci stiahnut a rozbalit dokumenty...su v pdf
http://data2.edisk.cz/stahni/14929/TDCI.zip_478.65kB.html
1,6 16V 08/2005
KK
PostPosted: Thu Feb 22, 2007 9:18 pm    Post subject: Reply with quote
Díky, mám zase do čeho chvíli koukat. Nemáš někde graf závislosti výkonu a spotřeby na otáčkách pro motor 1,4 Tdci?
KK
ivoivo
PostPosted: Sun Mar 11, 2007 5:50 pm    Post subject: ako vam reguje turbo Reply with quote
mam 1,4tdci na mojom motore vobec necitim nastup turba pri 2000 ot.
jazdil som na inych turbodiesloch a na nich je nastup turba pri urcitych otackach markantne citit.
dik za odpoved
mam najazdene 4000km
inac som spokojny spotreba 4,8-5,1l/100km
vecinou kratke vzdialenosti 10-15 km
1,4 tdci Strieborna Mondust 12/2006
PostPosted: Sun Mar 11, 2007 7:31 pm    Post subject: Reply with quote
no, ked si pred tym jazdil na silnom dvojlitry, tak sa necuduj :) Zalezi ako stupis na plyn, ale myslene je to, ze na plyn stupis len jemne a ono to zacne neprirodzene akcelerovat (teda oproti benzinom). Najmarkantnejsie je to na 1 a 2 stupni pri malej zatazi auta. Mne sa turboefekt paci, a prave na takychto slabych motoroch si ho vacsinou mas sancu uzit. Kamos co presadol zo silnej benzinovej audiny do mojho mini auta tiez nechapal kde je ten turboefekt ktory som mu den pred tym predviedol :)
PS: turboefekt=sekunda po zosliapnuti pedalu plynu, pocas ktorej sa pumpuje turbo a az potom pocitis zatah motora.
ivoivo
PostPosted: Sun Mar 11, 2007 8:53 pm    Post subject: Reply with quote
jazdim aj nanisane 2,5l turbodiesel tam to riadne tlaci do sedacky
a ešte sa chcem spytat zda sa že my slizi olej pod ventilovym kritom
ci mal niekto taky problem
PostPosted: Mon Mar 12, 2007 7:36 am    Post subject: Reply with quote
Co myslis pod ventilovy kryt? Nemyslis pod sraubickou kde sa vypusta olej? Ziadny olej zospodu nevidno, ale mozno ked lepsie opises ze kde, mozem sa hned na to pozriet.
pocuj, co znamena 12/07 v tvojom podpise?
Ford Fusion 1.4 TDCi 7/2006
ivoivo
PostPosted: Mon Mar 12, 2007 11:27 am    Post subject: Reply with quote
je to 12/06 kupa
to kde my to tecie dam foto
[/img]
Black storm
PostPosted: Mon Mar 12, 2007 3:32 pm    Post subject: Reply with quote
Pod ventilovym vekom to slzi ajmne a videl som to aj na dalsich troch Fuzacoch. Raz za pol roka to vystriekam cisticom na brzdy a je to.
PostPosted: Tue Mar 13, 2007 7:22 am    Post subject: Reply with quote
tu fotku sa ti nepodarilo spravit?
ivoivo
PostPosted: Tue Mar 13, 2007 7:58 pm    Post subject: foto Reply with quote
foto olej [img]http://img266.imageshack.us/my.php?image=img0286hp3.jpg[/img]
ivoivo
PostPosted: Fri Mar 16, 2007 9:52 pm    Post subject: Reply with quote
vcera my zacalo svietit oranžove svetielko kontrola motora
dnes som bol v servise vraj nejaky konektor nejakeho cidla bol povytiahnuty
ten olej co my pod ventilovou hlavou tecie, ojednaju tesnenie a o 10 dni ho pretesnia
Rolling Eyes
PostPosted: Fri Mar 23, 2007 9:06 am    Post subject: Reply with quote
Teraz som si spomenul ze som ti zabudol odpisat na ten slziaci olej. Ja to tam mam uplne suche. Ale mozno bude slzit niekde inde, lebo som si pred par dnami vsimol ze trosku oleja ubudlo. Teraz narychlo neviem ci kupit liter na dolievanie alebo pockat 3 mesiace na garancku. Pocul som ze na garancke vypustia len polovicu oleja, doleju a je to. Dufam ze to nie je pravda, ale zistit to nemas ako :( Na toto su dobre benzinaky. Tam vidis ci ti riadne vymenili olej.
Page 1 of 6
